| Product(s): | STAAD RCDC FE | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | General | ||
| Original Author: | Aaradhya Rahate, Bentley Technical Support Group | ||
Download Instructions
STAAD RCDC FE Connect Edition can be downloaded at the link here or from Bentley Cloud Services After signing into the CONNECTION Center, select Software Downloads under My Support. Once on the Software Fulfillment page, the installer can be located by performing a search on “STAAD RCDC FE”.
This article provides step-by-step instructions for successfully installing STAAD RCDC FE.
The STAAD Rcdc FE Installation Wizard opens.
2(Optional) To change the location where Rcdc FE is installed, either: type a folder path in the Installation Directory field
or
click the Browse button (…) next to Installation Directory field. In the Browse For Folder dialog that opens, browse to the drive and folder where you want to install STAAD. Rcdc FE, then click OK.
3.To read the End-User Licensing Agreement (EULA), click the Licensing Agreement
The End-User Licensing Agreement opens in a web browser.
4.After reading the license agreement, turn on the I accept the End User Licensing Terms check box if you understand and agree to the License Agreement Terms and Conditions.
Note that agreeing to the license agreement is required in order to install the product. Checking this box displays the Install button at the bottom of the wizard.
5.(Optional) Select the features which you want included in this installation.
By default, all features are selected. Some are required and may not be unselected.
6.Click Install. The installer downloads and installs the selected component features.
Note: If Windows prompts you with a User Account Control dialog, click Yes to proceed.
7.Click Finish.
To avoid any confusion, you click on LINK and refer Video of installation.
