04. How to modify the external pressure ring stiffener type and size?
05. How do I design a custom flange on a nozzle?
06. How to place Nozzle on Nozzle?
07. Does AutoPipe vessel contains "LIP type Nozzle"?
08. How do I model a nozzle on the bottom of a tank?
09. How do I model internal piping in AutoPIPE Vessel?
10. How is the nozzle fillet radius calculated for WRC calculations in AutoPIPE Vessel?
11. How to design Nonstandard flanges on standard Nozzles?
12. How to mode a nozzle attached directly to cone small diameter end?
13. How to model a Nozzle on a Nozzle in AutoPIPE Vessel?
14. How to specify offset for a nozzle on a Nozzle Bolted Cover?
15. How to take care of WRC for Nozzle on blind flange?
18. Local loads due to a nozzle in WRC 107/297: Why is the weld joint efficiency equal to 1?
20. How to set the nozzle projection from the insulation surface in an AutoPIPE Vessel model?
22. With which criteria Autopipe Vessel optimizes flanges?
23. Can you clarify these two parameters ‘d’ and ‘di’ in the report from AutoPIPE Vessel?
26. How to create a nozzle on head in AutoPIPE Vessel?
27. Nozzle report is given as "Set-on" although "Set-in" was selected in AutoPIPE Vessel, why?
28. Results are different for nozzles when using AutoPIPE Vessel instead of Microprotol
29. How to add a nozzle in AutoPIPE Vessel?
32. How to add B16.47 Series B flanges for sizes above DN600 in AutoPIPE Vessel?
33. How to add reducer on the nozzle in AutoPIPE Vessel?
34. How to model transition opening offset?
35. Complete nozzles design check report is missing for nozzle mounted on cap
36. ASME BPVC VIII, Div I, UG-45 NOZZLE NECK THICKNESS equation should use Can or Cav?
