| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | Beam Design | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
In RCDC CONNECT Edition, Beam ductile link is not calculated as per IS 13920-2016 cl 6.3.5 (b)
Please check and confirm.
The snap you have shared is from the original code. After that one amendment has been circulated where changes to this clause is mentioned as per the attached snap. We have incorporated this change and accordingly RCDC is showing the result.
