The following file is copied to the one of location when installing the application:
C:\Program Files\Bentley\AutoPIPE Translators\PDS Translator
C:\Bentley\AutoPIPE Translators\STRAIT\
This enclosure contains a Software Tool for converting Intergraph PDS Model Neutral Files into an AutoPIPE Batch Neutral File (*.NTL) which can be automatically saved as *.DAT file and opened in AutoPIPE. Bentley and Users have performed testing on a number of test models and found good translation results. Any translation issues found please send to support@bentley.com, subject “AutoPIPE” and we will fix and issue a patch for this translator in a timely manner.
User reference document updated. (installed with AutoPIPE 23.00.01.367)
Removed STRAIT from program title and renamed to "PDS to AutoPIPE Translator"
Icon updated.
64 bit build.
#473903: Add user reference button on the program.
Fix #11095 Add support of long file names (> 8 chars)
Fixed problem with CTL card
Shortcut is created under a new program group Programs> Bentley AutoPIPE Translators > STRAIT
A new drop down list to select a version of AutoPIPE installed to open the translated file
Add support for reading line number from PDS neutral file
Add support for Transition Joint mapped to 2 flanges For all Rigid Bodies (RB) import weight as added weight
Write AutoPIPE material names with spaces
Read and map PDS material names with spaces
