Import and export of piping models between CAD and AutoPIPE can save man hours in the creation and checking of piping and structural models and prevent errors associated with manual entry of piping models.
AutoPIPE can directly import CAD piping models from AutoPLANT (PXF, with additional PXD & PXH data), AutoPLANT Designer/Isometrics, ProPIPE, Caesar II Neutral (CII), and Aveva PDMS (CII). In addition, AutoPIPE can import structural steel models from Bentley STAAD and Multi-Steel; if the Multi-Steel model is composed of AISC structural elements in order to consider mass and flexibilities of structural supports as part of the piping analysis.
In addition, Bentley's CAE development team has produced a number of translators to convert other well known CAD system files that then could be opened by AutoPIPE. Please see the list of translators that are installed with Bentley AutoPIPE V8i 9.1.1.2 and higher:
Note: The most current versions of the translators are installed with the newest version of AutoPIPE. Therefore, the only way of procuring the most updated version of the translators software is by install the latest version of AutoPIPE.
The PCF translator will translate:
SmartPlant (*.pcf)
CADWorx (*.pcf)
SolidWorks (*.pcf)
AutoDesk Inventor (*.pcf)
CATIA (*.pcf)
Autodesk Plant3D (*.pcf)
Medusa
SmartPlant does have a richer data format which supports component stress attributes like: pressure, temperature, pipe weight, insulation etc. The PCF files generated by the other products mentioned only support geometry coordinates and nominal pipe size. We have found several 3rd party applications like Autodesk Inventor may not write a valid PCF files and the PCF translator will do the best conversion it can, but in these cases Autodesk would have to improve the quality of their exported PCF file.
This translator will only work with the PCF file created from one the multiple applications listed above. You may need to contact the application technical support to get a step by step procedure to create a PCF file. Some may even need a software add-on installed (like Solidworks needs an add-on called Routing that allows the user to model piping routes, which can then be transferred to AutoPIPE).
ADLPipe Pipe stress program used primarily in the nuclear power industry, converts ADL PIPE models to an *.ntl file format to be opened by AutoPIPE. Originally released in 1967, ADLPipe was the first commercially available piping analysis program and was bought by Bentley in 2008.
PDS is a comprehensive, intelligent computer-aided design/engineering (CAD/CAE) application for plant design, construction, and operations. There is some configuration.
With any PDS setup there is usually an amount of custom configuration of CAD components. The user is also required to install 2 PDS configuration files on the PDS side to generate a readable PDS stress neutral file. Therefore any out-of-box solution may not work the first time. Since Intergraph PDS has typically a high level of customization we recommend translating a few PDS models for you first to help configure the component mapping. PDS Stress Analysis Interface:
(PD_Stress -> PDS model neutral file (*.n) -> STRAIT -> AutoPIPE model neutral file (*.ntl) -> AutoPIPE program -> AutoPIPE model file (*.dat)
Note: see alternative approach here:
ME101 Translator is a tool that allows conversion of models from ME101 to Bentley AutoPIPE.
The translator reads the ASCII neutral file created by ME101 and produces an AutoPIPE database file with a user specified name and a “.DAT” extension.
These translators will be installed to the following folder:.
AutoPIPE CONNECT 23.00.00.230 and higher
C:\Program Files\Bentley\AutoPIPE Translators
\ADLPipe Translator
\ME101 Translator
\PCF Translator
\PDS Translator
AutoPIPE CONNECT 10.00.00.10 and 12.08.04.09
C:\Program Files (x86)\Bentley\AutoPIPE Translators\
\ADLPipe Translator
\PCF Translator
\STRAIT
AutoPIPE V8i v09.06.02.06 and lower
C:\Bentley\AutoPIPE Translators
\ADLPipe Translator
\PCF Translator
\STRAIT
If you have NOT installed AutoPIPE V8i 9.1.1.2 or higher and would still like to have the translators, please log a service request asking for the respective translator.
All translators have a reference manual included with-in each zip / installation folder for further details information.
