A. As Per BS EN 13445-3
Max allowable nozzle loads (Fmax), why Δ, K & α are zero?
Tubesheet, where do the terms l1, l1' and gamma (γ) come from?
Change the values for Clamp Wa and Wab
Set "d70" parameter
Why maximum test pressure of all component is not considered as vessel test pressure?
Allowable longitudinal compressive Stress (σ
c,all
) is not calculated as per EN13445-3 Clause 16.14-29, Why?
Nominal elastic limit is not calculated correctly. The nominal yield strength (σe) must be Rp1.0% / 1.3, Why it is not matching?
Calculate nozzle variables
Calculate the values of epsilon 1+ and 1-
Why is design pressure considered twice for head calculation in EN 13445-3?
How AutoPIPE Vessel calculates Longitudinal stress & General primary membrane stress intensity?
Bentley AutoPIPE Vessel
Support Solutions & FAQ's
Calculations
