Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> select a piping code to see the calculations performed by AutoPIPE.
Item #1: SIF on reducers is always 2.0
Item #2: Tees are not Overriding the User SIF's. Why?
Item #3: Values to use for reducer R2, L2, and Cone angle
Item #4: Crotch Radius and Crotch Thickness on a Welded / Contour tee
