- 20 - EXTERNAL PRESSURE: xxxx (No. xxx) INSUFFICIENT or NOT CONSIDERED
- 25 - Insufficient strength in shell/channel joint
- 27 - Longitudinal membrane stress in the tubes exceeded
- 28 - Longitudinal membrane stress in the shell exceeded
- 29 - Equivalent stress in the tubes exceeded
- 37 - STRESSES AND DISTORTIONS : Stress(es) exceed(s) allowable
- 52 - WRC 107-297: Local Load Error
- 77 - BRACKETS: error in reading file dimcon.emsd for current diameter.
- 89 - Allowable stress at temperature missing (95C)
- 98 - Unable to design geometrical plate layout without interference
- 113 - Tubesheet: modulus of elasticity at temperature missing (330 °C)
- 122 - Checking Data
- 151 - Design Code required isn't part of your license (ASME)
- 181 - Cone 3: should be placed between 2 shells
- 182 - No face detail on flange with gasket on both side of the bolt circle
- 215 - FLANGES 3710: allowable stress at temperature missing (XX °C).
- 216 - FLANGES 3710: ambient allowable stress missing.
- 217 - FLANGES 3710: exceptional ambient allowable stress missing.
- 235 - Floating Head (split ring): allowable stress
- 236 - Floating Head (split ring): allowable stress
- 237 - Floating Head (split ring): allowable stress
- 243 - FLOATING HEAD (crown): modulus of elasticity at ambient temperature missing.
- 262 - ANCHORAGE: Insufficient skirt/shell thickness at junction with anchor chairs
- 263 - NOZZLE xx: see detail in the calculation sheet
- 271 - MAXIMUM ALLOWABLE WORKING PRESSURE : maximum pressure < design pressure (xx MPa compartment No.xx)
- 287 - Error in formula [40*bd] for gasket according to AD B7
- 316 - PD 5500 Figure G.2.2-18 deflections of cyl. shells due to radial loads, values beyond curve boundaries
- 319 - HEAD: knuckle radius (XX in) not covered by code §UG-32 (j) (diameter=XX in , thickness=XX in
- 320 - HEAD: crown radius not covered by code §UG-32
- 331 - NOZZLE N1: Weld sizes are not adequate
- 334 - Tubesheet: Design code required ins't part of your License (ASME)
- 356 - Gasket width insufficient ( minimum=##.### mm ), the permissible gasket load is exceeded, use of a compression ring is recommended
- 404 - Flange xx.xx seating pressure less than or equal to zero
- 411 - Nozzle AP (pad) allowable stress at temp missing, exceptional ambient allowable stress missing
- 412 - Nozzle AP (pad) allowable stress at temp missing, exceptional ambient allowable stress missing
- 417 - Insufficient reinforcement
- 420 - LOCAL LOADS (lug): [EN 13445-3 16.7], a load exceeds the maximum allowable value.
- 423 - LOCAL LOADS (XX): EN 13445:2021 (2021-05), the combination of the stress ranges exceeds the maximum allowable value.
- 425 - Floating Head (split ring/splices): insufficient thickness or gap not maintained
- 438 - BEAM MODEL: the length of the equivalent beam (8,091 mm) is not equal to the length of the vessel (7,947 mm).
- 490 - FLAT HEAD: number of opening > 1 ==> out of the scope (the calculation has been made with the opening giving the greater thickness). Use an other code ( EN 13445-3 or BS/PD5500 ).
- 496 - Tubesheet : Fixed Tubesheets (or junctions with shell/channel) are different (the Tubesheet calculation is based on the front box sheet data).
- 515 - FLANGE 30.02 : insufficient flange thickness (design case No. 0).
- 538 - ADJACENT OPENINGS (nozzles C/D): nozzles are too close to one another ( 43.785 mm < 50 mm ).
- 587 - NOZZLE N1: nozzle neck thickness < required thickness per UG-45.
- 593 - Saddle effective angle < 30Deg (blast int Max P (Corroded inertias) (Corroded Weight), revise design of vessel
- 627 - Tubesheet: shell side diameter (XX mm) <= OTL (XX mm).
- 633 - The tube-to-Tubesheet joint strength is not adequate
- 650 - MDMT: unable to determine.
- 675 - GEOMETRY (xxx): thickness = xx mm (>= xxx mm) ==> PWHT is required.
- 677 - Conical Shell (XX.XX.XX) Under Internal Pressure: U-2(g) analysis is required or provide a flare at the small junction of the conical shell (Appendix 1-5(e))
- 732 - xxx: Allowable stress of xxx missing
- 746 - FATIGUE (Weld xx): Check material chemical properties
- 769 - ROOF: geometrical conditions not maintained.
- 771 - ROOF: stiffener at the roof-to-shell joint is insufficient.
- 772 - ROOF: Insufficient Support Column
- 773 - ROOF: Insufficient Rafter.
- 795 - API 650: design temperature >93 deg C.
- 811 - ROOF: Insufficient Girders.
- 822 - HEAD (xxx) UNDER INTERNAL PRESSURE: insufficient thickness.
- 885 - Tubesheet: tubesheets gasketed with shell are not possible for a fixed tubesheets heat exchanger
- 991 - NOZZLE XX : Not checked, only one central opening may be taken into account on bolted cover following EN13445 Annex G.
- 998 - Local Loads: Beyond curve boundaries (WRC 537 cannot be applied)
- 1026 - Compartment n°3 : pressure / temperature missing.
- 32768 - Program has encountered an error and will close now
- 77832 - Abnormal Termination message appears when starting AutoPIPE Vessel
- IDispatch::Invoke("LoadArx"=00000013) failed w/err 0x80020009
- Not a valid Material Database
- Output results required
- Timeout Exceeded (3600 s)
- Unknown Procal Release - Release 1
Bentley AutoPIPE Vessel
Support Solutions and FAQ's
Warning Messages
