AutoPIPE Vessel allows users to automatically generate both 2D and 3D drawings in various industry-standard formats. This article outlines the supported file types, software requirements, and steps for exporting drawings.
📤 Supported Drawing Formats
AutoPIPE Vessel supports the following formats for drawing generation:
| Drawing Type |
Format |
File Extension |
Notes |
| 2D |
DWG |
.dwg |
Compatible with AutoCAD / BricsCAD (Classical versions only) |
| 2D |
DGN |
.dgn |
Compatible with MicroStation |
| 3D |
SolidWorks |
.sldprt |
Requires SolidWorks installation |
⚠️ Note: AutoPIPE Vessel does not support AutoCAD/BricsCAD Lite versions.
🛠️ Software Requirements & Preferences
- DWG Generation (AutoCAD/BricsCAD):
- As of version 45.00.00.133, users no longer need an AutoCAD or BricsCAD license to generate
.dwg files.
- To generate
.dwg files without AutoCAD/BricsCAD, select DWG as the CAD software in the Preferences dialog.
- DGN Generation (MicroStation):
- Users can select MicroStation in Preferences to generate
.dgn files.
- Even without a MicroStation license or installation, drawings will still be generated because MicroStation is the default CAD option and uses embedded libraries within AutoPIPE Vessel.
- Generated
.dgn files can be opened using Bentley View, a free viewer.
- Using Installed CAD Software:
- If you have AutoCAD, BricsCAD, or SolidWorks installed, specify the CAD software and its executable path in the Preferences dialog.
- When using the Execute > Generate Drawing command:
- AutoPIPE Vessel will export the formatted file.
- It will automatically launch the specified CAD software using the provided path.
- The exported drawing will open directly in the selected application.
📂 Locating Exported Drawings
If no CAD software is specified:
- Navigate to the folder containing your AutoPIPE Vessel model.
- Locate the exported
.dgn or .dwg file.
- Open the file using a compatible viewer or CAD application.
🎥 Video Tutorial
Watch the video below for a step-by-step guide on generating and exporting drawings from AutoPIPE Vessel:
💡 Feature Requests
If you need support for additional file types or want to suggest new compatible CAD applications:
- Submit your ideas in Bentley IDEA Portal, Follow the instruction given here with detailed requirements and use cases.
