01. When choosing a 8" nominal shell size the O.D. is reflected as 8.78" O.D. (it should be 8.625").
02. How to import Aspentech edr file into AutoPIPE Vessel?
04. How to manage the baffle spacing of a heat exchanger in AutoPIPE Vessel?
05. How to manage the number of Tubesheets in an AutoPIPE Vessel heat exchanger
06. How to see the pass order number and how to change it in an AutoPIPE Vessel model?
08. Number of Heat exchanger tubes and path are different in the AutoPIPE Vessel report, why?
11. Why is tubesheet layout not full of tubes?
12. How can I insert the shell connection on the head of a heat exchanger in AutoPIPE Vessel?
15. Use TEMA Metric Bolt Root Area (TEMA Table D-5M) from section 9 in an AutoPIPE Vessel model.
16. Where to input extra cladding thickness on tubesheets in AutoPIPE Vessel?
18. How do I design a stacked heat exchanger?
19. How does AutoPIPE Vessel set the design conditions for tubesheet?
20. How to define shell length in different types of Heat Exchanger in AutoPIPE Vessel
22. Where do we mention MMT (Mean Metal Temp) in AutoPipe Vessel for Fix tube sheet Heat Exchanger?
24. Heat Exchanger Pass Partition Plate Modification
25. How to manage the baffle spacing of a heat exchanger?
27. How to use the Tube sheet Design Conditions dialog in AutoPIPE Vessel?
28. What is the difference between tubesheet design condition and design case?
31. How to model and design heat exchanger with shell dimension based on nominal pipe size?
32. How to specify shell ID instead of tube numbers in modeling the tube layout?
33. How is shell length for heat exchanger determined in AutoPIPE Vessel?
34. How can I input a specific bundle characteristics using AutoPIPE Vessel?
35. How AutoPIPE Vessel calculates the shell length at the time of Heat Exchanger Design?
36. How is shell length interpreted in AutoPIPE Vessel?
37. Is the corrosion allowance taken into account for the tubes in an ASME design?
39. What settings to use for DIC and OTL on the harness tab in AutoPIPE Vessel?
40. Baffles are deleted when deleting a Nozzle element
42. Tube Bundle report is not aligned with bundle layout
43. Axial tube stress and Tube to tubesheet joint check for U-tube tubesheet
44. Calculate MAP (New and cold)
45. Why relocation of the pass partition is reset when clicking on "compute" (heat exchanger)?
46. Calculate Maximum shear load;Qi
48. How to add different gasket In gasketed Tubesheet connection In AES Heat Exchanger?
AutoPIPE Vessel - Frequently Asked Questions
