Viewing Plate Stress/Moment Envelope Plots
Product(s):STAAD Foundation Advanced
Version(s):ALL
Environment: ALL
Area: Postprocessing
Subarea: N/A
Original Author:Kris, Bentley Technical Support Group
Question:
I am trying to see a graphical representation of the envelope of plate stresses and/or moments--how can this be done?
Answer:
Recently STAAD.pro was updated to include the option of viewing colored contour plots displaying plate results for an envelope of loads.  Previously these plots could only be displayed on a load case by load case basis.
The following steps can be used to utilize this feature:
1.  Run the analysis and go into Post Processing.
2.  Under the Results ribbon, go to Layouts -> Plate Stress as shown below:
3.  In the dialog box that appears, choose "Envelope" in the Load Case menu, select the desired stress type (say, MY (local)), and click Apply then OK:
4.  The colored stress contour showing the stress envelope will appear on screen:
