This page contains a list of Known Issues found in the current version of STAAD.Pro identified after the application has been released.
Note that for the Known Issues that may be of concern that are known to exist in the application at the time of release, please refer to the section Known Issues of the ReadMe that is part of the installation and can be accessed from the Help backstage of the application.
For High and Critical Known Issues that have been identified in builds of STAAD.Pro V22, see V22 Known Issues
For known issues that relate to STAAD.Pro CONNECT Edition see CONNECT Edition Known Issues
For known issues that relate to earlier V8i versions of STAAD.Pro see V8i Known Issues
