Document Information
Document Type: FAQ
Product(s): LEAP GEOMATH / BRIDGE PARAMETRIC LAYOUT
Version(s): All
Original Author: Bentley Technical Support Group -VM
QUESTION: How to export 2D , 3D drawing from Geomath / Bridge Parametric Layout to MicroStation ?
ANSWER:
- Click on Alignment from the Alignment Tree.
- Then click on Alignment Tie and a new dialog box will appear on the screen.
- Keep the North and East co-ordinate as it is and copy the information to Notepad.
- Then export the file as 2D or 3D and in the Export Dialog Box Paste those coordinates as X and Y of the global origin and then click “OK”.
- Then user should be able to see the exported 2D or 3D drawing in MicroStation.
- The alignment will be set to the correct X and Y coordinate.
/resized-image/__size/320x240/__key/communityserver-wikis-components-files/00-00-00-00-15/pastedimage1604999240354v2.png
