| Product(s): | STAAD.Pro Advanced | ||
| Version(s): | N/A | ||
| Area: | Analysis Solutions | ||
| Subarea: | Advanced Analysis | ||
| Original Author: | Jeremy Hoesly, Bentley Technical Support Group | ||
The STAAD.Pro Advanced license ( Advanced Analysis Plus Engine license for STAAD.Pro v8i ) brings with it the following advantages :
In STAAD.Pro CONNECT Edition, you must configure your license to use STAAD.Pro Advanced feature as shown here.
To use Advanced Analysis capabilities within STAAD.pro SELECT series 6, the user must specifically request the use of the Advanced Analysis Plus Engine option on the start screen:
Otherwise, when attempting to run one of the Advanced Analysis options the following type of warning will appear:
[[Configure STAAD.Pro CONNECT edition for Advanced Analysis]]
[[SELECTsupport TechNotes and FAQs]]
