Document Type: FAQ
Product(s): LEAP CONBOX
Version(s): All
Original Author: Bentley Leap Bridge Technical Support Group – VM
QUESTION: What are the different types of Losses which are available in Conbox?
ANSWER:
The different types of losses are :
1) ACI-209R-92
2) CEB-FIP-90
3) LRFD 6
4) Lump Sum
If the user selects any of the first 3 types of losses then the program will internally calculate the losses as per the respective code equations.
If the user selects Lump sum option then the user has to calculate the losses by hand and then input in Conbox .
