| Version(s): | 07.01.04.16 | ||
| Area: | Text | ||
| Subarea: | General | ||
How to Copy/paste multiple lines of text, and paste them in a different order to how they are viewed.
Copy/paste multiple line of text, pastes then in a different order to how they are viewed.
Using the selection tool + CTRL key, select the text in the order you want them pasted, then use wset add;wset drop - (or order element front in V8 - also edit > bring to front menu item).
