Document Type: FAQ
Product(s): LEAP CONBOX/CIP RC/PT Girder
Version(s): All
Original Author: Bentley Leap Bridge Technical Support Group – VM
ANSWER:
The default option selected in CONBOX is Strain Compatibility.
For Strain Compatibility all rebar's at top or bottom will be considered in ultimate moment capacity calculation.
When Equations option is selected only the steel on the tensile side of the section is used (H/2) for moment capacity calculation.
