VBA interface error: unable to get IDE
  Product(s):   MicroStation
  Version(s):   V8i
  Environment:    N/A
  Area:    Programming
  Subarea:    VBA
  Original Author:   Sven Zigelski, Bentley Technical Support Group
Problem Description
When I´m trying to start the Visual Basic Editor, I get the error message "VBA interface error: unable to get IDE...".
Steps to Resolve
  1.  Find the directory
         C:\Program Files\Common Files\Microsoft Shared\VBA\VBA6\ (32-bit operating system)
         or
         C:\Program Files (x86) \Common Files\Microsoft Shared\VBA\VBA6\ (64-bit operating system)
  2.  It should contain a directory 1033 at least. "1033" also stands for the English country code.
  3.  If the country settings of the machine differ from the English settings, there must be an appropriate folder for your country settings. For example, "1031" for Germany. In this case create this folder and copy the contents of folder "1033" to folder "1031". Find your code here: http://technet.microsoft.com/en-us/library/dd346950.aspx, section "Language Codes".
  4.  Otherwise, it may be helpful to summarize the contents of both folders together and store it into both Folders.
Other language sources
Français
