Applies To | |||
Product(s): | STAAD.Pro | ||
Version(s): | V8i | ||
Environment: | N/A | ||
Area: | Concrete Design | ||
Subarea: | American Concrete Design | ||
Original Author: | Bentley Technical Support Group | ||
I am in the Shearwall Design page but when I look at the Shear Wall Design Whole Structure window on the right, I cannot see the list of design parameters as shown next
Solution :
To fix the problem, please close all programs. Go to Control Panel > Appearance and Personalization > Display > Change the size of the text and other items by choosing the Smaller - 100% ( default ) option. Click on Apply. You will need to log off and log back in for the settings to take effect.
