| Version(s): | 08.09.00.92 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
Significance of a dimension style that is in blue text or highlighted in blue when selected from the dimension style dialog box.
This indicates that a setting in the dimension style has changed and has not been saved. Once the dimension style is saved, the dimension style name will revert to black.
