Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group - VM
ANSWER:
User needs to click on the Combination button in the Loads TAB and in the new window "Load Combinations" the user needs to click on ADD button and then he/she can input the custom LC name and the respective load factors .
To Edit an existing load combination the user needs to click on the EDIT button and then he/she can modify the LC factors.
Please see the attached screenshots for more information.
