| Version: | V8, V8i | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles |
When placing a note it shows the arrow but when the note is placed it changes to a tick mark.
Go to Element > Dimensions > Terminator Symbols and change the Arrow setting from cell back to default.
In V8i :
Go to Element > Dimension Styles > Geometry tab > Terminators  and change the Symbols > Arrow setting back to default.
