| Version(s): | 08.09.00.92 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
Dimension settings are grayed out when selecting it from the dimension
styles dialog. Why is this happening?
The dimension style that is selected is from a dgnlib file and is currently not used in the design file. Once the dimension style is used, a copy of the dimension style will be copied to the local file. At this point in time, the settings will then be available.
