Product(s): | MicroStation | ||
Version(s): | 10.05.00.40 | ||
Environment: | N\A | ||
Area: | Animation | ||
Subarea: | General |
The following will demonstrate how to animate a cutout in a 3D model
On occasions, it is useful to provide an animation to show what's inside part of a 3D model. For example, you may want to show the rooms owned in a large building, or see what is beneath a roads surface.
How-to-create-an-opening-in-a-model-when-rendering
Original Author: | Carl Myhill |
