Product: | MicroStation | ||
Version: | V7 or /J | ||
Environment: | N\A | ||
Area: | Licensing | ||
Subarea: | Activation |
I have installed MicroStation J and have an Activation Key. How do get MicroStation /J license activated?
There are two parts to Activate the license for MicroStation /J.
1) Install SELECT Gateway in the computer where you want to install the gateway.
2) Point the gateway to the SELECTserver site and your activation key, by editing msj.lic
Part 1 is to install the Gateway,
To download (from the Website):
Select either ONE (1) depending on your PC:
Once signed in, Follow:
SUPPORT > (https://www.bentley.com/en/support)
GO TO CONNECTION CENTER > (https://connect.bentley.com/)
Part 2 is to place a MSJ.LIC file in the licensing folder.
Create a txt file (Notepad) and save the file as msj.lic; and fill in the computername (computer where MicroStation J and Gateway is installed)
It will read :
SERVER=xxxxxxxxx
xxxxxxxxx > fill in yourcomputername
Then save this file and place it to C:\Bentley\Program\Licensing
Original Author: | Judy Wong |
