| Version(s): | All | ||
| Area: | Steel Design | ||
| Subarea: | General Steel Design Solutions | ||
The KL/r value that STAAD reports for the Y axis for a single angle does not match what I get from my hand calculation. Can you explain why?
For single angles, the local Y and Z axes are the principal axes as shown below:
The KL/r value is computed using ry and rz which are based on the principal axis system. Chances are that your handculation uses the geometric axes.
