Applies To | |||
Product(s): | MICROSTATION | ||
Version(s): | 05.07.00.25 | ||
Environment: | N\A | ||
Area: | Visualization | ||
Subarea: | Render | ||
Original Author: | Bentley Technical Support Group | ||
Ray Trace is not rendering elements in reflections.
Ray Trace is not casting light through colored glass that is off scene.
Reason:
"Render All Objects" is not enabled in Ray Tracing settings.
When disabled, only elements totally inside or partially inside will be
included in rendering.
1. From Menubar, go to Settings > Rendering > Raytracing.
2. Enable "Render All Objects".
Notes:
This can effect elements outside the scene that may be seen in
reflections of elements inside scene.
