Beam Splice Joints
In RAM Connection, Beam Splice (BS) Joints can be created with the following configurations:
Shear Connections
Connector
| Design Code | Beam Sections | Connection Options |
- AISC: Single Plate (SP)
- AS: Web Bolted Cover Plate (WCP)
- BS: Web Bolted Cover Plate (WCP)
- CSA: Web Bolted Cover Plate (WCP)
- EN: Web Bolted Cover Plate (WCP)
- GB: Web Bolted Cover Plate (WCP)
- IS: Web Bolted Cover Plate (WCP)
- NZS: Web Bolted Cover Plate (WCP)
- Beam Size: Beams may be different depths.
- Beam Shape: Beams may be different shapes.
- Connection Type: Bolted (default) or Welded
- Connection Type to Beam: Bolted (default) or Welded
In addition to the connection specific options listed in the table above, the following member configuration can be customized for beam-splice connections for shear reactions can be customized in the connection pad:
- Centered: The alignment of the right beam and left beam can be customized in the Connection Pad:
Moment Connections
Connector
- AISC: Flange Plate (FP)
- AS: Flange Bolted Cover Plate (FPBS)
- BS: Flange Bolted Cover Plate (FPBS)
- CSA: Flange Bolted Cover Plate (FPBS)
- EN: Flange Bolted Cover Plate (FCP)
- GB: Flange Bolted Cover Plate (FCP)
- IS: Flange Bolted Cover Plate (FCP)
- NZS: Flange Bolted Cover Plate (FPBS)
- Beam Size: Beams must be the same depth.
- Beam Shape: Beams must be the same shape.
- Connection Type: Bolted or Welded
- Interior Plates are available for Bolted Connections
- AS: Directly Welded Flanges (DWBS)
Shear & Moment Connections (Combined Connections)
Connector
- I-Shaped
- Tapered I-Shaped
- Haunched I-Shaped
- Vertical Angle: Max 30º
- AISC: Moment End Plate (MEP)
- AS: Bolted End Plate (BEPBS)
- BS: Bolted End Plate (BEPBS)
- CSA: Bolted End Plate (BEPBS)
- EN: Bolted End Plate (BEPBS)
- IS: Bolted End Plate (MEPBS)
- NZS: Bolted End Plate (BEPBS)
- I-Shaped
- Tapered I-Shaped
- Haunched I-Shaped
- Beam Stiffeners: Available in the Connection Pad.
- AISC: End Plate HSS Moment (EP)
- AS: End Plate HSS Moment (EP)
- CSA: End Plate HSS Moment (EP)
- EN: End Plate HSS Moment (EP)
- Bolt Configuration: 4 Bolts (default) or 8 Bolts
Axial Connections
Connector
- AISC: End Plate HSS (EP)
- AS: End Plate HSS (EP)
- CSA: End Plate HSS (EP)
- EN: End Plate HSS (EP)
- NZS: End Plate HSS (EP)
In RAM Connection, axial forces can be assigned to the beam splice as follows:
- Tension: Positive Axial Force
- Compression: Negative Axial Force
