Steel (H-steel) Pile properties
Document Information
Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group - VM
QUESTION:  what material properties needs to be used when H-steel piles are used for pile bents ?
ANSWER:
If the user assigns H steel pile while analyzing pile bents , then the program considers the properties of the concrete piles as there is no option to input steel properties in the geometry TAB. User has to manually change to steel material properties .
