Shared cells - Cells - MicroStation
Create Cell Library from DWG Shared Cells
Delete Empty Levels with Defined Shared Cells
Drop shared cell to geometry
How do I create a cell library from shared cells in a DGN file or blocks in a DWG file?
How to delete shared cells?
How to drop all shared cells?
Point and Graphic shared cells to be placed as View Independent by default
Unable to remove the shared cell in the library
