| Version(s): | 08.05.02.27 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
Is there a way to define a variable through keyin?
Using configuration variables in key-ins
As an alternative to using the Configuration dialog box (Workspace > Configuration ), you can define a configuration variable from the Key-in window using the key-in EXPAND SET. For example, to create a configuration variable MYFILE having as its value the name of the open DGN file, key in EXPAND SET MYFILE = $(_dgnfile) ? note that there must be a space both before and after =.
You can also use configuration variables as parameters in key-ins. For example, to create a cell whose name is the name of the open DGN file (without the extension), key in $ CREATE CELL $(basename(_dgnfile)). In this example the first $ is an alias for the key-in EXPAND KEYIN. In other words, the key-in EXPAND KEYIN CREATE CELL $(basename(_d gnfile)) is equivalent. The second $ indicates what follows in parentheses is a configuration variable.
To check the value of a configuration variable, key in EXPAND ECHO $( <(><<)>configuration_variable>) ? for example, EXPAND ECHO $(MS_DESIGNSEED).
The value is displayed in Message Center.
