Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group - VM
ANSWER:
In Structure Model ,
P represents the PLASTIC HINGE LOCATIONS -->
@ COLUMN TOP --> Cap Column joint
@ COLUMN BOTTOM --> Column base.
F represents the Flexural/Shear CAP Design --> @ FACE OF SUPPORT.
