| Version(s): | ALL | ||
| Environment: | ALL | ||
| Subarea: | Geometry | ||
How can I change my input units in the STAAD.Pro CONNECT Edition ?
OR
How can I set my input units in the STAAD.Pro CONNECT Edition?
You need to follow the steps shown in the pictures below
From the Geometry ribbon menu within the Analytical Modeling Workflow, click on the input units icon
In the resulting dropdown, choose the appropriate units for Length and Force and then click Apply
This would set the input unit or allow you to change the input unit
You can confirm whether the input unit has been set correctly or not by looking at the status bar at the bottom right hand corner of the application window
