| Version(s): | 07.01.04.10 | ||
| Area: | Custom Linestyles | ||
| Subarea: | N\A | ||
How to a check a corrupt .rsc file
Product: MicroStation J V7
Version: 07.01.04.10
Area: Custom Linestyles
You can check the structure of the resource file by using the RDUMP utility which is located in :
Bentley> Program > MicroStation > MDL >Bin directory.
Move your resource file to this directory and from the Microstation Development shell type in lower case:
Through Development Shell Change directories to the rdump.exe in the MDL> BIN Directory
Then run the following:
rdump -x <(><<)>filename>
This will show you the structure of the resource file and check the files integrity
Then from the same directory type:
rlib -o <(><<)>newfilename> -v <(><<)>oldfilename>
This will create a new resource file and merge the old one into it.
https://communities.bentley.com/products/microstation/w/microstation__wiki/14628/how-to-check-if-a-rsc-file-is-corrupted
