Applies To | |||
Product(s): | STAAD.Pro | ||
Version(s): | All | ||
Environment: | N/A | ||
Area: | Modeling Solutions | ||
Subarea: | Properties | ||
Original Author: | Bentley Technical Support Group | ||
How do I assign WT sections to members in my model?
There is no database of WT profiles in STAAD--instead they are meant to be "cut" from the wide flange sections. Simply access the database of wide flanges, select one with appropriate dimensions, and change the type specification to "T (Tee Section Cut From Beam" as shown in the screenshot below
