Document Information
Document Type: FAQ
Product(s): LEAP BRIDGE CONCRETE
Version(s): All
Original Author: Bentley Technical Support Group -VM
QUESTION: Is the Bridge Parametric Layout module is still active?
ANSWER:
In V20.00.00.58 standalone version of Leap Bridge Concrete, the Bridge Parametric Layout module was still active.
In V21.01.00.22 OBD version of Leap Bridge Concrete, the Bridge Parametric Layout module has been deactivated.
