RM Bridge can perform SSI – Soil-Structure Interaction inside OpenBridge Designer with the addition of the structure underground infrastructure with foundations’ details and soil modeling springs. The soil-spring constants can be extracted from gINT reports or from a more complete PLAXIS modeling of the soil and the forces.
Moreover, when needed, PLAXIS can create the foundation model with detailed soil-structure interaction consideration through interface elements. It provides any structural forces in the piles along with soil reaction-displacement curves. In an equivalent linear indirect SSI analysis, the kinematic and inertial analysis of the Soil-Structure Interaction will then make sense because all the additional modeling and analysis effort could lead to significant savings in the structure design.
More information can be found in the FAQ Demo Example from the link below.
