The FEM is based on the element's full bodies and it needs a set of additional definitions and subfunctions to display these complex FEM results. Usually, the integral results for the full overall cross-section are automatically created and Lines could be computed on each side of the Shell elements. Therefore, in general, it would be not necessary to specifically generate any Line or Area Integrals.
Though these two functions are provided, Line and Area Integrals are to be used for different purposes that allow users to enhance the ability to get significant local results with RM Bridge FEM analysis:
| RM Notation | Shell Theory | Description |
| Nx | ∫∫σx dydz | Normal force in x-direction |
| Qy | ∫∫τxy dydz | Shear force in xy plane |
| Qz | ∫∫τxz dydz | Shear force in xz plane |
| Mx | ∫∫z× τxy dydz +∫∫y× τxz dydz | Torsion moment |
| My | ∫∫z×σx dydz | Bending moment around y-direction |
| Mz | ∫∫y×σx dydz | Bending moment around z-direction |
| Nx | ∫σx dz | Normal force in x-direction |
| Qy | ∫σy dz | Normal force in y-direction |
| Qz | ∫τxy dz | Shear force in plane of shell element |
| Mx | ∫z×σx dz | Bending moment around x-direction |
| My | ∫z×σy dz | Bending moment around y-direction |
| Mz | ∫z×τxy dz | Torsional moment (in element plane) |
Sort longitudinal or Transversal is the option that allows for searching for a sequence of transversal results in a diagram line of different body series. A much more detailed explanation can be found at the document RM Bridge FEM Application Guide and the Training Example 08. FEM.
