| Version(s): | ALL | ||
| Environment: | ALL | ||
| Subarea: | Other | ||
| Original Author: | Modestas Turulis, Bentley Technical Support Group | ||
How to turn off the labels of some specific entities like nodes or members?
In some models, it could happen that some numbers of nodes/members/plates/solids are overlapping each other. To make the reading clearer, the user can turn off labels of some specific nodes/members/plates/solids. To do that, first of all switch on the node (shift + N), member (shift + B), plates (shift + P) or solid numbers (shift + C). Then go to View menu and select the required Individual Label option from the Labels menu group, i.e. Individual Beam Label:
In the dialog which appears, click Yes:
Now click on the specific beam and its label will be removed. Click on the beam again and then its number will be shown again.
To switch back all labels, go to View -> Label Settings and deselect the option 'Use Partial Labeling Mode'.
