| Version(s): | 08.05.02.35 | ||
| Area: | DWG | ||
| Subarea: | Save | ||
Saving to dwg and Graphic Groups are lost.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.35
Area: DWG
AutoCAD does not support the MicroStation Graphic Groups, but does
support Named Groups. If a Graphic Group is turned into a Named Group,
and the Named Group toggle is on in the Save As dwg Options under the
Filter tab, the Named Groups will translate in the dwg format.
