Version 9.10 is the first Bentley-built release of the Linux version of ADINA.
The compilers and compilation options for the Linux version have been revised as part of the Bentley build procedure.
The minimum operating system requirements for the Linux version have also been revised, see the table below.
The installation and licensing of the Linux version have also been revised.
For more information for installation and licensing, see ADINA Installation & Licensing for Linux
After installation, all files can be found in ./ADINA/bin. We recommend that you add
./ADINA/bin to the PATH environment variable.
Four scripts are used to run the ADINA system programs:
adina9.10, symbolic link to adina.bash
Invokes the ADINA solvers
adadp9.10, symbolic link to adadp.bash Invokes SAM adaptive meshing
ai9.10, symbolic link to ai.bash
Invokes the Graph utility program, the adaptive meshing interface or the solver user interface.
aui9.10, symbolic link to aui.bash
Invokes the AUI
These scripts have been extensively revised in version 9.10.
By default, if version 9.9 is already installed, the Windows installer will install version 9.10 adjacent to version 9.9. Version 9.9 should be uninstalled before installing version 9.10, if only a single installed version is desired.
In version 9.10, for the solvers, the default number of threads used is equal to the number of physical cores on the computer. The default memory allocation for the AUI and the solvers is equal to half of the physical memory (RAM) on the computer.
e.g. If the computer has 6 physical cores and 32 GB memory, the command
adina9.10 ... (Linux) adinas.exe … (Windows)
will use 6 cores and 16 GB memory by default. Use the -t flag to specify a different number of cores and use the -mm flag to specify a different memory allocation. The Linux command
aui9.10 ...
will use 16 GB RAM by default. For AUI on Windows and Linux in interactive mode, the memory used in the last interactive session will be used. Use the -m flag to specify a different memory allocation.
Platform |
Operating system |
Fortran compiler |
Intel MKL library |
Windows |
Windows 8, 8.1, 10, 11 |
Intel Fortran Compiler Classic, version 2022.1.0 |
MKL 2022.1.0 |
Linux |
Linux kernel 5.4 and higher, glibc 2.31 and higher |
MKL 2022.1.0 |
4 ADINA System 9.10 Release Notes Updates for 9.10
Ubuntu 20.04 LTS openSUSE 15.4 Centos Stream 9
Red Hat Enterprise Linux 9
Distros earlier than the above cannot be used with ADINA.
libssl.so.1.1 is a system library used with OpenSSL 1.1.1.
The following documents are available with the ADINA System.
ADINA Handbook
Written as a task-oriented desktop reference, the ADINA Handbook helps users to quickly and effectively leverage ADINA's advanced geometric modeling, meshing, and visualization features.
ADINA User Interface Command Reference Manual (CRM)
Volume I: ADINA Solids & Structures Model Definition
Volume II: ADINA Thermal Model Definition
Volume III: ADINA CFD & FSI Model Definition
Volume IV: ADINA EM Model Definition
Volume V: Display Processing
ADINA Primer
Theory and Modeling Guide (TMG)
Volume III: ADINA CFD&FSI
Volume IV: ADINA EM
ADINA Verification Manual
ADINA-Nastran Interface Manual
TRANSOR for Femap Users Guide
