| Applies To | | |
| Product(s): | STAAD.Pro | |
| Version(s): | All | |
| Environment: | N/A | |
| Area: | Post processing | |
| Subarea: | | |
| Original Author: | Bentley Technical Support Group | |
How to change the plate stress contour color to customize the view in the post processing tab?
- Click on the colour (in the screenshot is red colour is selected)
- A new color box window will open, and you can choose the colour as per your requirement. Either you can select colors from "Basic colors”, or you can also select custom colors from "Define Custom Colors >>" option
