Product(s): | RAM Structural System | ||
Version(s): | 15.03 | ||
Area: | General | ||
Original Author: | Payel Sasmal, Bentley Technical Support Group |
When I run RAM Structural System, it opens fine, but I get the following notification in the RSS News feed: "Unable to Display Notifications"
RSS news feed is not being displayed. This could be to a temporary internet problem or a blocked service.
Make sure that you are logged in to the Connection Client. If you are logged in you will find the Connection Client Logo in the taskbar.
If you are logged in, still you are unable to see the RSS feed section, then close RAM Manager. Exit from the Connection Client .
Run the Connection client from the short-cut in your desktop and log in back.
Alternatively, the sourse of the news feed can also be read through a browser using: http://www.feeds.rapidfeeds.com/8826/
Structural Product TechNotes And FAQs
