Recalc Window Basic Settings: 2. Schedule Options
At the CalculationsSchedule Options, in the Recalc Window, the user can select one of the following four possible options for the calculations in the schedule:
Sch
Also, the Summation Load case can be defined: usually, it is created with a name or number, like STG-SUM or 1000, using the load management function. It's the load case where the current summation state due to previous permanent load cases is added.
