Canadian Steel Code S16
 Product(s):STAAD.Pro
 Version(s):All
 Environment: N/A
 Area: Steel Design Codes
 Subarea:
CSA S16
This page contains a list of Wikis which are related to the Canadian Steel Design codes (CAN/CSA-S16-01/09/14/19).
  1. I am designing a structure as per Canadian S16-01 code and have changed the value of LY significantly for one of the members. The utilization ratio however does not change. Why is that ?
  2. [[Canadian Steel code verification of an I shaped Steel section subject to pure axial force per CSA -S16-14]]
