PROBLEM: Every time I click on ProjectWise from OpenBridge Designer dialog I get auto signed in and logged into a data source. How can auto login be turned off?
SOLUTION: To disable "auto-login next" to a DataSource follow these steps.
If ProjectWise Explorer Client open, click on Tools and open Network Configuration Settings dialog.
If ProjectWise Dialog is not open, you can open Control Panel and open "ProjectWise Network".
