OBD & RM Bridge View
RM Bridge View has been deprecated and it will no longer be included in RM Bridge starting with OBD CE 2021 Release 2.
For Users to continue having access to RM View, it is necessary to keep the installation of OBDv10.10.00.XX, or one earlier program version, side by side with OBDv10.10.20.XX or a latest version.
The User will be able to use RM Bridge View that is included in OBDv10.10.00.XX by following these steps:
  1. Start RM Bridge from OBDv10.10.20.XX.
  2. Open Program Settings.
  3. Click Edit button from Environment section.
  4. Click New button from “Define internal program environments” dialog.
  5. Add a new variable. Name-rview; Value=1.
  6. Close all dialogs and also RM Bridge.
  7. Next time when RM Bridge will be launch from OBDv10.10.20.XX it will show the RMView menu tree item.
More information can be found at the video at the link below:
KB0114895 v1.0
