| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | General Solutions | ||
| Subarea: | Learning Material | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
How to access Help File for STAAD.Pro Connect Edition?
Launch STAAD.Pro. Go to the top right hand corner and find the blue "?" sign. Click on it to open help file.
Alternatively you can press "F1" to open the help file.
You can also access HELP file from File > Help > contents.
Please note all the help documents are stored as .html files in the below location.
C:\Program Files\Bentley\Engineering\STAAD.Pro CONNECT Edition\Help
Whenever you try to launch help file this will open in a browser even if no internet connection is there. If in any case you are not able to launch help file with the above process go to the above location where .html files are stored. Now just select a file and try to open it with any browser and make that one as default settings.
