| Product(s): | MicroStation V8, V8i | ||
| Version(s): | N\A | ||
| Area: | GUI | ||
| Subarea: | General | ||
In Settings > Design File, Category Color, three colors can be configured:
- Element Highlight Color
- Drawing Pointer Color
- Selection Set Color
How to configure these using key-ins?
Use preprocessor key-ins:
To enable different highlight colors for Element Highlight Color and - Selection Set Color:
"mdl keyin calculat calc tcb->selectionHiliteOverride=1"
To set the Element Highlight Color to yellow:
"mdl keyin calculat calc tcb->hiliteColor=6"
To set the Drawing Pointer Color to red:
"mdl keyin calculat calc tcb->xorColor=4"
To set the Selection Set Color to cyan:
"mdl keyin calculat calc tcb->selectionHiliteColor=3"
For the color numbers in the above three key-ins a number from 0 to 9 must be used:
0 black
1 blue
2 green
3 cyan
4 red
5 pink
6 yellow
7 white
8 light grey
9 dark grey
These settings are saved with the design file. File > Save Settings to keep the settings for the next MicroStation session.
MicroStation Product Communities
Other Language Sources
