| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | General Solutions | ||
| Subarea: | General Information | ||
I see a number of files created in the same folder where my STAAD.Pro model is, each having a different extension. Can you please let me know what these files are for ?
STAAD.Pro creates a bunch of auxiliary data files within the same folder in which the STAAD.Pro model is created. The following table lists these different extensions along with the data types stored in each of these files. This table can be downloaded from the Attachments section on the top right corner.
